Think mine need replacing. Managed to blow brand new Bosch sidelights within a month... Where can they be bought from? And are they easy to fit? - didnt see any screws to remove the wires.
Scrappy? And my guess is that the loom has the split pins that goes into the connector, may be worth cutting them off and attaching new ones soldering and heat shrinking.
But i'm confident that it's not the connector blocks, unless they look battered.
You're best to check the earth first. If you have a multimeter check for resitance from the connector to the bateries earth. Should be virtually 0.
