You'll need to chop the legs down as 150mm is a bit long , better too long than too short though , then you've got something to play about with . I just got a 13mm silicone hose as well and a 13mm 90 degree bend , a small piece of plastic tube in the end of the 13mm bend and made a hole in the 70mm 90 degree hose with a blob of silicone sealant to hold it secure.
