Since fitting prolines my car pulls to right (tracking has been done)
Car  PH1 172 Sport
As title my car pulls very slightly to the right since I fitted my Prolines. I had my tracking done by laser last week when I had two new tyres fitted and he said it was out by 1mm and adjusted it but the car is exactly the same as it was before. I have been back there and there equipment is saying that the tracking is set as it should be in there book.
Is there anything else it could be?
new tyres? are they different to the ones you replaced
john @ progrip was telling me he had a guy with a civic type R who had just had new tyres and springs fitted and then had lazer alignment done, and was complianing about it pulling, got it back up on the ramps and it was spot on but still pulling, he said you would be surprized how much difference the tyres can make!
All four are PE2's. Pressures are spot on front and back as well. I'm stumpped!
The only thing I can think of atm is that I rotated the rears to the front and put the new tyres on the back. Maybe the rears have worn in such a way that when they were put on the front the car now pulls slightly??
I did this a day after fitting my prolines so maybe its not the springs at all?
swap the tires back to how they were and see how it is then. i didn't have any problems fitting sportlines to my old car
I can't really be bothered tbh as where I live the best thing I have to jack the car on is a deep gravel drive and its a royal pain in the backside!
It only pulls very very very slightly so ill double check the pressures and that the springs are seated correctly and then get Rentech to check the allignment again when I go for an MOT at the end of the month if it hasn't changed.
