Noticed over the last couple of weeks when turning the ignition on in the ph1 there is a 1 second delay in starting until it fires up, basically a slow cranking blip.
As i suspected would end up happening eventually it now won't start until repeat trying / leaving it and trying again.
Battery is fine, would imagine this means the alternator is holding charge so again ok?, it turns over so starter possibly fine?
So thinking:
Crank position sensor
Spark Plugs
HT Leads
Coil Pack
Which of the above would most likely cause a consistent initial slow cranking over?
So thinking:
Spark Plugs
HT Leads
Coil Pack
