Slow cranking now issues starting
  Ph1
Noticed over the last couple of weeks when turning the ignition on in the ph1 there is a 1 second delay in starting until it fires up, basically a slow cranking blip.
As i suspected would end up happening eventually it now won't start until repeat trying / leaving it and trying again.
Battery is fine, would imagine this means the alternator is holding charge so again ok?, it turns over so starter possibly fine?
So thinking:
Crank position sensor
Spark Plugs
HT Leads
Coil Pack
​Which of the above would most likely cause a consistent initial slow cranking over?
  Trophy Turbo :)
Yes the coil pack, remove a plug, fit it to lead and turn over check for a spark on each lead, this will rule out plugs and coils pack.
Once that's done if all is ok put back how it was, then pull fuel pipe off and get a bottle put the pipe in, get a mate to crank it over, when you turn IGN on you will get fuel but see if it's pumping when you crank it if not then check crank sensor by replacing.
