BREMBO said:
What is clay and how do u do it ???
this is the product -
http://www.meguiars.co.uk/cgi-bin/specwd.pl?pc=G1116&tp=0
You can get it in most car accessory shops
It uses the clay to get rid of stains and other chemicals etc on your paintwork i.e. tar spots. that a normal wash won't remove.
You use the detailer spray to stop the clay sticking to the paint surface and you rub the clay on the surface of your paintwork to remove stains .
When the clay bar surface your using gets dirty, you knead the clay bar until it becaomes a clean surface again. ( bit like bread making
I must warn you though, If your expecting to do this in 5 minutes, don't bother, it can take a minimum of 1.5 hours to do... :dapprove:
But the result is WELL WORTH the wait
