it might help pull it out , if not drill and tap it the broken stud , put a treaded bar into it, put 2 nuts on tighten them up against each other pretty dam tight, then try and undo the nut with a ratchet again, good luck,
tbh i love anything like this , i see it as a challenge, good luck anyway pal,
This happened to me a while ago... I shat a Brick. I ended up driving it round to a garage and they used a blowtorch to get it out. Tool about 20mins abd the guy only took a 20 quid note for doin it
Did the same when replacing my rear dampers, proper s*** myself when it first happened but managed to get grips on it. Hope you get it sorted poriordan anyway.
so everyone knows i gt this drilled by a garage and nut and bolted it, its now mint ohhh it took hrs ahaahaha bolts tuffened or some sh*t but is doable
