G gasman15 Car Clio RS 172 Jun 26, 2014 #1 When removing the gearbox from my 172, some of the bolts have snapped. Due to the position it is impossible to get access to the bottom of the bolt, any one any ideas as to how they can be removed? thanks matt
G gasman15 Car Clio RS 172 Jun 26, 2014 #3 Head of the bolts have snapped when using a breaker bar :-(
J Jaff. Jun 26, 2014 #4 Un-f**king-lucky! probably have to drill it out and get an easy out on it or drill and tap it
J Jaff. Jun 26, 2014 #7 If they're too tight I doubt you'd get much luck with an easy out but it's worth a go before tapping it
Carbonraider ClioSport Club Member Car Raider, 172, the van Jun 26, 2014 #8 Wouldn't it be easier removing all bolts, drop the subframe and remove captive nuts with remaining bolt still in place. I would of thought the captive nuts would give way before the bolt to be honest.
D Dan@SJM Car 07969 124504 Jun 26, 2014 #9 100% the captive nuts would've spun. Unless the OP is talking about the 13mm ones.
J Jaff. Jun 26, 2014 #10 I'd drop the subframe anyway purely for access reasons tbh. Know a welder? Weld a nut onto the broken bolt and try again?
B bloke Car dan's cast offs. Jun 26, 2014 #11 gasman15 said: Silly question what's an easy out?! Click to expand... something you should never use...http://www.screwfix.com/p/screw-extractor-5-piece-set/18643 when they snap in the bolt you're trying to remove they are a pain to get out.
Matt e ClioSport Club Member Car Megane R26 Jun 26, 2014 #12 bloke said: something you should never use...http://www.screwfix.com/p/screw-extractor-5-piece-set/18643 when they snap in the bolt you're trying to remove they are a pain to get out. Click to expand... and they nearly always snap, there made of cheese
