	Hi all new user here...hope someone here can help and i find a good home for forum use...
i'm planning on soldering these wires together.. its a clio mkII 1.5 dci under drivers seat ...if that makes a difference ?
its not the grey connector block that seems to be in tact..its the brown smaller one...and the black round connector block ....
can any1 confirm the correct way to solder them
iv read that it's the opposite to passenger side...i.e.. blue to blue ? brown to brown ? however the problem as you can see...is that 3 wires need joining up....
after looking at the passenger side its connected blue to brown, and orange to brown...
and there is a separate black wire connected to a black wire - which should be easy enough - does anyone know what this wire is for?
im pretty certain the grey block is pre tensioner ? brown air bag ? and black ?
and am i right in thinking best way is to disconnect the negative battery terminal for about 20 mins before hand ?
thanks for your help
