solid top mounts talk to me
rubber mounts tend to dampen vibration and road noise rather than acting like the spring and dampers
I understand that - but I wouldn't have thought they'd suddenly make the car feel "crashy"
I fitted billsteins and then a month later solid mounts. Made no difference to the feeling - just turns in quicker
Top mounts won't make the ride crashy LOL
That's down to spring strength and shock absorbers
Really?? well, that would defy physics - and common sense - so LOL back at yah!
You replace something made of rubber, with shock absorbing qualities, with something solid.
Why do you think solid top mounts change the steering feel, and 'sharpen it up' like people say. They merely remove that small element of travel provided by the rubber. That small amount of travel will also obviously have an impact on ride quality. The crashiness of bumps in the road is definitely felt more with solid top mounts. Probably a price worth paying but it is definitely true.
Noise, vibration and harshness - all pretty relevant to this discussion.
The rubber lets the shock absorbers move slightly from side to side = softer turn in. The solid mounts dont = faster turn in
The rubber will provide some noise reduction because it'll buffer the spring/shock movement from the car - but "crashy" feelings are when you hit a bump or pot hole in the road and the car jumps up or down harshly. That's NEVER gonna be caused by replacing half an inch of solid rubber with a solid mount. It will most likely be caused by either springs too strong or shock absorbers too stiff.
If the shocks and springs are soft enough they will absorb any movement in the wheel
If you'd said there was slightly more noise I'd agree - but saying it makes the ride "crashy" is absolutely absurd
I have ktec mounts also,great bit of kit,looks great and good handling upgrade,as said turn in is sharper with much more driver feedback.I think if the car is mainly a road few track day's a year car then ktec mounts are fine,if it was more track then road then I would go AST or Mark Fish,not seen the pure sport mounts,do you have a pic of them fitted cup_Phil?
ive got the compbrake, never had a problem with them
well i got offered some compbrake ( que haters ) at a decentish price so i decided to find out how bad they are lol, wish me luck
Ahh mine are type a ( the crap ones apparantly ) and until now i didnt knwo type 2 existed, they do look exactly like the k-tec ones tho :/
Yeah the first gen comp brake ones are utter shite - I'd rather have standard
The second gen ones are fine - and are identical to K-Tec
I believe K-Tec just bought the rights to them - powder coated them and stook a K-Tec logo on them
im not saying anoyone is telling lies but i couldnt see how they could be so bad, so for the price i paid i decided there was only one way to find out lol, ill proberbly get some k-tec ones in the near future lol
They are a horrid design
They don't fit well in the hole and there's nothing to hold them in place except a silly screw-on ring
That rattles loose and the damn things move about - meaning a crap drive
There's a reason comp-brake discontinued them and redesigned them as above with the bolts going through the strut tops ;)
i agree dude, which part of the bottom bit doesnt fit exactly ? how hard would it be to make some more on the lathe ? and use the bearing out of em ?
It's not worth it really - you can buy the bearings from pure motorsport for about £20 lol
By the time you've lathed some new ones you might as well just buy the k-tec ones :(
how good are the bearings for £20 quid?
and do you have a link ?
tar jamie
edit, found em, are the compbrake bearings also 18mm ?
I didn't even know the K-Tec ones were originally Compbrakes (if they really are that is lol)
Jamie the ones you got will be grand :) just tighten them up really well in the turret - that's what I did
I am dude, just gonna bang em on for a few week see how they go, can't do any harm, also did you have the little spacer on with them as they wasn't in the box ?
No spacer, just what is cable-tied to keep it together :)
You're maybe thinking of the spacer for the standard-shock knocking fix?
are they f**k. Myself and Darren at OMEX designed them, with me basically telling him what was needed, and he did it (him being the ex cheif engineer at Marcos and now at TTS) on commision from Ktec. Compbrake ripped off the design as their old one was s**t
Ahhh sorry assumed the opposite - as compbrake stopped selling them about the same time I saw the k-tec ones advertised
AFAIK compbrake don't manufacture the clio top mounts any more
no ive seen in threads that there should be a little collet type spacer about 10 or 15mm long, if you didnt use it and it didnt knock tho it should be ok :)
Just remembered this video of my Trophy top mounts which I think were OK !!
<a href="http://www.youtube.com/watch?v=AiRuzClLFhk" target="_blank">
Bump here...
My 172 cup has some anodised red solid top mounts fitted with new renault shocks and H&R springs.
I think the tip mounts are the ones listed on ebay but I'm unsure.
Anyways, when I hit a pothole I get a really harsh bang, could this be knackered topmounts or is it something else?
I found the solid top mounts make hitting bumps a lot louder. It's still worth having them on there in my opinion, but essentially you replace a piece of rubber which isolated the road noise with a spherical bearing that doesn't...
