Hi All,
Just wondering if any of you can give me some advice before I give up on this car :boring:
From day one it has been plauged with electrical issues making it run poorly,
The most recent one which I cant seem to get to the bottom of is the car misfiring loads and almost stalling when cold, the problem isnt anywhere near as bad after a minute or so but misfire is still noticeable at low revs,
I have tried the following:
The list goes on and on to be honest and the car is still running very poorly and showing poor MPG,
Now I am running out of ideas but since I have thrown so much money at this car trying to get it fixed it would seem a shame to give up now,
I have been reading people saying NGK spark plugs and Renaults dont agree (those are what I put in when also changing the coil pack) so I have some original Renault spark plugs on order.
Can anyone else think of anything that may be worth trying other than the obvious and scrapping this french pile of crap
I was thinking if all else fails go down the route of replacing the wiring loom, does anyone have any expierenced with this?
Any advice will be greatly appreciated,
Thanks, Sam
- Changed coil pack & spark plugs
- Cleaned Throttle Body
- Took rocker cover off and gave the engine a good clean and checked for any blocked breather pipes
- Replaced the MAP sensor
- Replaced the Coolant Temp Sensor
- Took off the black box at the back of the engine and repaired wiring
- Replaced lambda sensor before cat
- Replaced TDC sensor
Thanks, Sam
