Something hanging down.....
....looks like it's coming from the plastic shield at the bottom of the engine.
Looks like some kind of foam/insulation type thing. Thought I'd run over a bag or something but when using a pole to try and remove it found it was this!
Any idea's what it could be, and whether I should just leave it or would it be best to remove it?
Is it related in any way to the recent oil change I had done?
I accept that I am a mechanical r****d......
it sounds like the liner for the undertray - not needed if it's badly damaged; if it's OK, whip the undertray off and put it back in
It's sort of half in/half out, just looks unsightly. Don't have access to a ramp to remove it either unfortunately. Would it cause a problem to leave it there, or if I somehow reached under and pulled the lining out? Don't really want to have to go back to the garage if I can help it.....
you need a 10mm spanner/socket - the undertray's held up by a bolt in each corner - can probably remove it without jacking it up. failing that, just pull it out. can't see it causing a problem, but guess you wouldn't want it getting wrapped up in a driveshaft or the exhaust system or something
