ive owned the car since beginning of december ive had nothing but problems with it ive had a new clutch fitted a new exhaust fitted a new drive shaft fitted both driveshafts where taken out and checked one was changed for a new one, but still i persist to get problems when its driven above 5 thousand rpm there is a noise that sounds like wheel spin like a vibrating sound almost it only happens after 5thousand rpm all the way to redline in 1st gear 2nd gear and 3rd sometimes when you pull off in 1st it vibrates a little bit if you come off the clutch abit quick under the 5 thousand rpm zone. ive had a look in the engine bay i cant see anything loose its had a brand new clutch fitted a brand new driveshaft and all the mounts have been checked out gearbox mounts/engine mounts and all the rubbers are still in tact im really starting to loose faith in this car because it keeps letting me down i would appreciate any good ideas to what it might be thanks luke.
