Spacer stuck on bolt
I have bump steer adjustment rod ends but its bent the bottom spacer between the rose joint and the nut. Ive managed to make around 1-2mm of clearance but the spacer isnt budging, ive tried to hit the edge that seems to be the part thats stopping it from moving but not much luck.
Ill probably end up going somewhere to get them off as I have no heat gun or axle grinders or anything like that. But wondering if theres something I can try before I give up?
I dont want to do back up the nut and torque it down because it took ages to make the room i did but Im thinking that will maybe align things?
