Spacers,Can i?
  RenaultSport clio 172 mk2
but use longer bolts to be safe
Thought it was OK to use the standard bolts providing the spacer was no more than 5mm?
Is there any problem if you use too long a bolt? Is there the potential for it to not be able to screw in far enough to hold the wheel tight against the hub?
Christopher
  Z4M
always play it safe and order longer bolts!
it's only a trip to halfrauds, and it could safe your life.
