I want to order some spacers so I can fix my PMS studs into these rather than the hubs.
But I'm not sure what size to go for, what's safe, what might cause my tyres to rub on the arches etc.
I've got ASTs yet to be fitted and will be going with the maximum camber these allow (not camber bolts too as I've heard these can knock out)
Will also be going with a good setup from the likes of Mark Fish or similar local place - so I'm not sure how the height will be just yet either..
So does anyone also have ASTs and spacers. If so what sizes do you run and do you get any rubbing issues?
Was thinking 20mm on the front and 15mm on the rears. Bolt to hub type. Then secure my PMS studs into these.
Not that it matters but was thinking H&R for the brand as I run these on another car and they've cause no problems.
Cheers for any input chaps.
