Is there anyway to remove the Mk1 spare wheel cradle without cutting? Thanks all.
R Rip3z Valver Lookalike Mk1 Ph3 Jan 24, 2006 #1 Is there anyway to remove the Mk1 spare wheel cradle without cutting? Thanks all.
Pat_986 1996 Valver Jan 24, 2006 #3 yes-just undo the bolt (from the boot) holding the cradle up, Take out the wheel, and the metal frame just lifts/clips out!
R Rip3z Valver Lookalike Mk1 Ph3 Jan 24, 2006 #5 That's some wierd looking bolt, what do I use to undo it?
R Rip3z Valver Lookalike Mk1 Ph3 Jan 24, 2006 #7 Ok not sure if I've understood this correctly. I've got to the stage where I can unclip the back end of the cradle (if there was a spare wheel there I could get it out). But the 2 hooks by the rear axle, I can't twist them to unhook the whole cradle.
Da Less Jan 24, 2006 #11 jack it up higher or use ramps maybe so the car is higher allowing the cradle to swing lower till the hooks un-hook. Maybe find a mate with a pit?
F Final Maxim Punto/Clio GTT Jan 24, 2006 #13 i didnt jack mine up when i took mine off, just ragged it. put some effort into it ya pansy
R Rip3z Valver Lookalike Mk1 Ph3 Jan 24, 2006 #14 Final_Maxim said: i didnt jack mine up when i took mine off, just ragged it. put some effort into it ya pansy Click to expand... Lol. RIGHT THAT'S IT! I'M GOIN TO GO TRY DO IT IN THE DARK!
R Rip3z Valver Lookalike Mk1 Ph3 Jan 24, 2006 #15 Hooah! I kicked the b*****d till it fell off! Now who's the pansy shaven ballz!
Pat_986 1996 Valver Jan 25, 2006 #17 no Probs mate, if all els fails you can always rely on a good kick!!!
R Rip3z Valver Lookalike Mk1 Ph3 Jan 25, 2006 #18 Bet that saves a few kilos. Saves it being check on the MOT too.
