I'd just use a ring spanner. The socket with the slit in it is a pain in the dick.
Is there an official tool? I've never removed spark plugs before, so don't want to damage anything![]()
I'm located in Derbyshire, so we're about a 3 hour drive away mate! Can you link me through to the tool on the internet? Thanks guys for all your help!
isn't that a lambda sensor socket?
spark plug sockets are normal sockets with rubber bits in the end, so when you pull the socket out, if the plug is loose it comes out when you remove the socket.
Good luck changing the plugs with that.
