spark plugs for 182 cup
  Clio 182 cup
So, I feel like I am opening a can of worms here! I'm a brand new Clio owner and feel like I have a lot to learn!
I've had the car 3 weeks, not driven it very much, it's had quite a lumpy idle and when I took it out last night it developed a constant misfire!! Sounds like it's only firing on three!
I suspect (hope!) it's a spark plug, so plan to renew them all, but there seems to be controversy about what to use?
Help please...........
Mbeau
  Clio 172
Genuine plugs is all you need. Or I use the R26 ones. @George@RTR_Parts will e able to sort you out.
Have you got a flashing EML along with the misfire? They suffer injector problems a lot. Along with the usual leads and coilpacks.
  Clio 182 cup
The EML has been on solid most of the time, something I needed to investigate anyway! but started flashing when it started missing
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
I can get you sorted with the correct plugs , and injectors, leads, coilpack etc aswel if needed. The 172/182 don't like other plugs barring the NGK, so check what's in the car and condition of them
Send me a message once you know what you're after mate
correct plugs:
  Clio 182 cup
Thank you George
Do you think it's most likely an injector? if so how much are they?
Do you have an email address i could use?
Steve
  Clio 172 ph1
You can check the resistance of your injectors to see if they are at fault - should be around 16 ohms.
Also 100% recommend ordering from George if you haven't already - ordered from him a few weeks back and got the parts the next morning!
