Spax rsx fitting issue
.Joe
Hi there, I'm currently in the process of fitting some spax coilovers and the rears seem to go straight through
I fitted my spax rear coilovers recently had no problems if the threads are going through that much they must be assembled incorrectly or missing the rubber bushes or something have you got the fitting instructions? If not then email spax they should be able to email you a copy but bear in mind that the newer rear coilovers are different (no helper spring) so make sure u have the correct fitting instructions.
Hi Dan, i just check now, i'm purely now just trying to find a correctly threaded nut, i have a feeling its unf just not too sure on size.
