speaker wiring
just want to know if you think this would work, i dont want to run a seperate amp for the 6x9s but i do want them left in. cheers folks
are the rears run from an amp?
if not then it won't work and melt the audio IC in your hu
it would be perfectly fine run off an amp and would present a 2 ohm load but you may cause problems for the h/u at high volume after some time of playing;)
no, was going to cut off standard connectors, add some thicker wiring, put spades on to connect to back door speakers,then piggy back the 6x9s off them.
only run the 2 12" subs off the amp
