Is there more than one type? Phase 1 172.
Matt@codered Clio. Jan 3, 2013 #3 Ok cool, can't get this one to fit....:dapprove: looks like the hole is a few mm too small.
DannyR 182, SQ7, Trafic Jan 3, 2013 #6 Should just slide in, massive arse to get, but easy in. Will only go in one way too if I remember rightly.
Matt@codered Clio. Jan 3, 2013 #7 Slide in yes, unless there is a bit of the old one still in there.... I'll have another look, otherwise I'll skim it down in the lathe.
D Dan519 DON'T SEND ME PM'S!! Jan 3, 2013 #8 takes a bit of a push to get the last bit fuly engaged. Put some lube on the O-ring, that'll help it slip in
Matt@codered Clio. Jan 3, 2013 #9 I'm only hoping its a 172 gearbox now....although if I check the part on dialogys it seems the same across most of the mk2 range.:S
D Dan519 DON'T SEND ME PM'S!! Jan 3, 2013 #10 look down the hole before you fit the sensor. if it's not blind the sensor will fit.
