speedo chance from lever fuel gauge to digital
  clio 1.5 DCI 80
is it possible to change the clocks from the type with lever fuel and temp to the type with digital ones? is it just plug and play?
obviously the whole cluster will need to be changed.
thats the one thing that i would have liked to have with my Dci but it didnt have it.
im sure somebody must have fitted one, but it depemds on how easy the swap is.
many thanks
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
You can do it yes but you will need the UCH reconfiguring so it knows about the new type of speedo head that you've fitted. If you don't the digital section won't work correctly as it'll still be setup for the analogue setup so fuel, data and temp sections will be wrong without calibration.
