Speedo needle vibrating on startup?
Car  The Beast MK4
Hey folks
When I start up the car the speedo needle is flickering a bit for about 3 seconds max. Have any of you experienced this? The trip comp is also reseting randomly but a quick search showed that a change of battery may fix this. Would the battery change also sort this problem?
We are talking about a Mk2 Phase 2 172 here.
Bump, anyone got any clues?
Or is this more suited to the Technical section, if so could a mod please move it.
Yep chnage the battery seem to help some dahbaords have failed but if your cars say 4 years old+ chnage the battery.
Bump for this thread.
How do you fix it if you don't mind my asking?
Getting pissed off with the clock dissappearing and the CD Player cutting out.
Take the top of the dash. In the center there should be a earthing point check its got a good connection.
