split washer bottle
  clio 172 MKII
Just wondering if anyone else has experienced this. kept filling the windscreen washer bottle up only to notice it was pi**ing out the bottom. Rang Camden Renault in Milton Keynes and the told me that Imthe third person with a Clio to call this week with the same problem!!
Covered under warranty but must be a fault - could be due to the cold weather....
  FN2 Type R +MK6 Golf
Had mine done in the summer last year,its a b*****d of a job and theyll keep it all day.Bonet off,wipers off etc,etc,and its rite underneath it all.look at it in the daylight and youll see what i mean.
Good luck,
ian
Had mine replaced, they take the wipers off but not the bonnet and only took em 40mins while I watched.....apart from the six weeks it took to get a new washer bottle!!
  Focus ST3 + proper Mini
mine was changed in october. (When they finally got the right one!!) they had the car for about 5 hrs as there had to sort a scratch and other minor warrenty work out.
Mine is leaking but it seems to be dripping from the pasenger headlamp washer until it reaches a certain level and then its fine....
Any idea if it is the same thing?
  clio 172 MKII
I dont think its the same thing AK - you fill mine up and in about 2 mins flat its empty!
take it in mate -it should be covered
  172 cup,s2 rs turbo
commen problem.they split near where the washer pump sits.easy enough to change though.
