Spoiler brake light not working
Car  BlackGold 182
Hi guys I have a problem with my brake light on my cup spoiler, since I've had the car it hasn't ever worked
the other 2 brake lights, I have fiddled around with the wiring and still bt having it
have you taken the whole light unit out and cleaned the connectors?
might be worth checking if there is a voltage just to rule out a wiring issue but it could be a new light unit job.
Had a similar problem on my mom's Micra. Mot guy said the LED lamp were shot (very unlikely).
Got it home and found a broken wire in the rubber grommet on the hinge of the tailgate.
As Klem said, you need to check the voltage at the lamp to see if it's a supply or a lamp problem.
Ian.
