i literally just gave it a scrub with a washing up liquid/water mixture and tooth brush and then just sprayed the silver straight on... was quite impressed as my spraying of other things in the past has been somewhat to be desired lolWat was your method mitch thats not a bad finish
cam cover i take you mean? people usually just mask the s**t out of the bay 2 avoid overspray... mine will be getting done at a later date when it gets its cambelt done as il remove it then and do it out of the bayAnother question how do i go about spraying the part under the inlets?
