springs
Car  1.2 mk2 ph2
i have tried fitting new springs, there is a problem that the rear has increased in height, could anyone explain why? or could someone explain a step by step guide so i can compare with the process i have used. when changing the springs (fk 40mm) do i have to simply replace the old ones with the new or is there anything else that needs to be done with it? cheers for any help.
