springs
^nope, the shock will tear open the CV boots if you do that!
remove the struts from the car and undo the top nut, simples
it wont fly off and hit anything ie. my teeth ?
then when re-doing you just compress them with your own force pushin the top mount on ?
Yep,
Loosen it off while the car is on the ground etc then remove the strut from the car before undoing the top mount nut, they will be under tension but nothing a bit of bodyweight won't counteract - take your time , don't rush and you will be fine
