squeak squeak fcukin squeak
hi all, got a really really anoying noise coming from right hand side of the clio,
as you can see from the tiltle is fcuking squeaks ALL the time, its wrecking me! seems to be coming from the front right wheel, any ideas? brakes? salt from the road? please help i cant go on like this..............lol
cheers, steve
Check your CV Joint. My driverside front wheel is squeaking like a biatch as the metal clip has split so its not on right anymore.
Ive had my 172 to bits trying to rectify rattles and squeaks. Its like painting the Forth Bridge... its a job that has no conclusion....
As soon as you have silenced one rattle, a squeak of equal or greater magnitude will appear elsewhere in the car. The only truly effective solution I have found so far is to turn up my stereo. Seriously!!
tell me about,ive never known a car like it for squeaks and rattles.
Quote: Originally posted by JAY172 on 06 March 2004
my cup gots loads of interior squeaks/rattles.sick of fixing them!
Remove your interior... I did. Nothing rattles now, as you cant hear sh*t. Problem solved,
most of them from the dash though.i know you people are into weight saving but removing the dashboard is going a bit far;)
Mine squeaked until my wheel bearing was changed. Even a new bearing could squeak if it was torqued to the wrong settings. (which was why my NEW bearing went in 5 months)
I think its embarrising having squeaky brakes because that draws so much attention. Mine squeak once or twice at the start of the journey. After that they are fine.
Ive also got a rattling seatbelt and front passenger seat. Maybe because ive lowered my car 60mm with stiff suspension?
Its squeaking all the time Andy. Your brake pads are not in contact with the disc unless pressure is applied to the pedel or the calipers are sticking.
My wheel bearing would squeak but then stop when you braked. Is that what yours does stevo20?
