AndyBMX
Megane 265 / Tuono
So for the last few months, every time I go above 70mph, I get a horrible high pitched squealing noise coming from around the windscreen area. I searched on here a while back and people were suggesting it was to do with wing mirror holes, poorly fitting doors etc, but there was also a suggestion that the windscreen seal allows air in and causes a squeal.
The other day I got up to 70/80 and the noise started, so I pushed around the edge of the windscreen, and found an length of about 10-15" behind the rear view mirror, where if I push it the noise stops. This has led me to believe that's the area of the windscreen seal that's letting air in.
So my question is, has anyone had this problem, and what is the best thing to use to try and re-seal with windscreen?
Any help is much appreciated.
