Squeeking when on full lock!?!:-(
Car  VX220 lightning
Hi, Just got my 182 cup and as I turned into my drive there was a squeek from what sounds... this only happens when its on full lock.... is this normal?
Adam
sounds like you need the washer mod...
the squeak is from the mounts on the suspention towers, the gap gets smaller when you turn the wheel.
ushally a knock.. i wouldent worry about it too much, add some lube to stop the squeak.
has the 182 got powers steering or the weirdo electric rack?? if its normal p/s check fluid level and pump (aux) belt tension
