Drivers side?? My standards ones in mine are squeaking from drivers side. Think its the plastic rubbing on the bit near the bottom on the door. Might be similar???
I had a rattle/squeak when I went over bumps and round corners coming my Trophy drivers seat.
Annoyed me so much I took the seat out the other day and found out the problem was a pound coin and a couple of ten pence coins that had got into the plastic bit behind the seat and moving about. Not sure if that gives you any pointers but it might do!
This is a common fault with Trophies. Mine didn't used to do it but has started to do it. Taking the seats out will only take 30 mins if you want to give it a go but I read it was due to the plastic clips underneath anyway.
