stabilising / derattling a magnex exhaust
i took mine to powerflow took prolly 5cm off that section n welded it back instead of using that clamp
well i only just got the clamp on - the mechanic had left the joint just sitting there the pratt!!! SO when i loosen the clamp i reckon i can that tube in around another 3cm by using a hammer - which should be just enough for me :-)
ill see how i get on next wkend when i get round to it
Quote: Originally posted by benji&eka on 13 August 2005
made myself. can supply a limited number for a fiver each,
the parts list is:
dunlop self level valve end (adapted)
m8 nutsert
m8 stainless steel bolt
m8 stainless steel flat washer
What are the measurements of the rubber stop?????
I dont have rubber but mayby im going to make it from nylon
after reading all your stories i was worried as id just bought a magnex cat-back exhaust 6" oval for my 172 mk2, so when i took my exhaust to have it put on i told the guy putting it on the problem & he used the renault mount the extra magnex mount and he fabricated another 1 its brilliant, able to move slightly but no noise at all & very strong!!! i live in bham & the guys called dusty ,he works for wheelworks in balsal heath. i recomend anyone with this problem who lives in the west midlands area to go and see him!
ps. it sounds and feels brilliant, like having a new car !!!
well i solved it.
I followed gt_gazs suggestions, but still i got a rattle. So me and my old man got pissed off. Drilled 2 holes in the suspension arm running under the car - put a U-shaped clamp over the top of the exhaust and tightened it up (it still allows some free movement which exhausts need i should think)- now it wont f**king move anywhere. No more rattles on the heatshield anyway
