I just got out of work. Started my car, Reversed and the car cut out or stalled. The second time it happened the little box with a heart beat came on and a coil type sign came up.
Coil pakcs fail loads on petrol worse on the 1.4 and 1.6 for some reaosn and ther eindividual you cna usualy tell though as they do make the whole running go wierd as such.
TDC is the top dead center sensor its a common problem £20 for a new one.
When it happened last time i took it to a guy and he said it sounded like a Rev managmenet problem or something. Its like a unit at the top of the engine, in a silver metal casing with wires going into it.
As you can sort of tell im not mechanically minded so i dont know what im talkin about!
My old 1.4 used to do this every morning, and pretty much every time i reversed, used to piss me right off. I found if i backed off the accelerator slowly and put the clutch in it didnt do it as much, never did find out what caused it...
