starter motor sticking... continues to turn engine over with the key removed!
Car  ph2 172 berg
Hi, my starter motor is sticking on even when i remove the key completely it continues to turn the engine over
any one got any ideas what it could be ? any help will be much appreciated! :)
Thanks Glen
Get a volt meter onto the trigger why for the solenoid, and then you can tell if the solenoid itself is sticking or if its a switching issue.
Thanks!... will give that a try :)
what you mean by switching issue ? sorry if i sound dull not too good with the electrical side :L
I mean like the ignition barrel staying in the "on" state for the starter circuit because the spring hasnt returned it properly when you release the key.
Hope its not that! wouldnt that mean a new barrel ? hopefully its just the solenoid
