Starting a Forum
Car  MK5 Fiesta Zetec S
Basically just want some guidance, im looking to start my own forum, I'm not that stupid but not exactly capable of making a HTML code site or whatever. Is it as simple of buying a domain, with a forum template and just adding from there?
Don't make them about pyramid schemes, AloeVera or bathmates and you should be safe. (from the likes of medici6666666)
There's free ones which will do everything for you, but not let you do much.
Then there's the "proper" route. You'd be amazed at how simple it is to build a forum with vBulletin, for example, these days. Probably 95% of what you see in the "forum" bit of this site is all down to just setting basic options in a user-friendly control panel. If you go the "proper route" (installing proper forum software on your own domain) make sure you pick a good domain from the start. Domain accounts for a lot of your SEO. SEO accounts for sign ups. Sign ups account for ads, which = the thing paying for itself. "proper" forum software works like anything else, pay for the license, download files, put them where the instructions tell you to.
EDIT: Picking your forum software is very important to as you're basically stuck with what you pick. Makes a big difference in the security, amount of ad-ons (little "apps" basically for users to use) and the amount of options you have. You'll also notice basic phpBB based forum looks a million times less proffesional than a basic vBulletin forum for example.
Domain name is a very small factor for SEO.
Get some hosting with CPanel and Fantastico (very common to have this on CPanel) and it will set up a forum for you in a matter of minutes without any technical know how.
