Hello all,
When I start my car it will turn over, but then sort of stall itself? Il turn the key and instead of starting, stall/just won't start. Then il straight away turn the key again and it'll start, but run a bit lumpy (but that may just be because its a 172) ..: I don't care so much about the running lumpy as its always sort of done that, I just want it to start first time like it used to!!!
Things I've done to try and fix this...
I've changed the spark plugs to brand new NGK PFR6E-10's, I've cleaned the crank sensor, I've sourced a secondary coilpack which seems to almost have made it worse :S so considering refitting my coilpack again... I've cleaned out the throttle body. I'm stuck now for what to do!
Any other sensors I need to look At? Or could it be an earthing issue, is that something to check?
It's driving me mad now.
Thanks in advance
Thanks in advance
