starting issue
  clio 172 cup
I have had problems starting recently some times its starts first time other times it doesn't but when I come back to it 20 mins later it starts have a blue tdc sensor but only had it in 6 months could it be that? Also it cranks over fine but just won't start it's doing my nut in can anyone help
ADS_V6
  172 cup clio v6 st
hi got a cup like yourself had similar problem from cold and hot start,i replaced the coolant temp sensor and car battery and that worked,see if the trip computer keeps resetting itself,if so prob the battery m8
  clio 172 cup
The battery was replaced 6 months ago would the cts cause it not to start?
ADS_V6
  172 cup clio v6 st
hi yes the cts can cause starting problems,i replaced the tdc and loom it didnt fix mine,the fault was the cts it would crank but not fire,i think a faulty 1 causes probs with the ecu etc,got mine from gsf car parts they got a third off at the moment
  clio 172 cup
Oh ok would love it if it was that it's driving me crazy only had the car 1 month love it but scared I am going to get stranded
ADS_V6
  172 cup clio v6 st
try that first its a cheap part around 20 quid,would happen right on new year lol,hope you fix it
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
The pump is one thing, pressure regulation is another... Same assembly but not the same thing.
You really should have it looked at though as it could be electrical or mechanical.
  clio 172 cup
Will do mate its doing my head in its totally random then I leave it for three hours and it starts first time
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Without certain equipment though you're going to be guessing. Sometimes guessing/changing a common part is fine or is an exceptable gamble. Paying for a proper diagnostic session, not a code reading session, can be money well spent as it will tell you exactly what is wrong.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Like I said, without equipment to see what's actually not happening when it happens, you are just going to be left scratching your head.
  clio 172 cup
Booked the car in got it back and they are saying about immobiliser issue that's cutting the fuel anyone had this?
  clio 172 cup
I think I have found out how to start it when it's cracking over if I hold the lock button on the dash it starts what could that be?
  clio 172 cup
Reanult in Aldershot have had the car three days now are just waiting for it not to start so they can investigate it since they have had it it's done it once but once they pushed it in to the workshop it started just hope I can fix this really don't want to have to get rid of it will be a very very sad man
Love this car
  clio 172 cup
Reanult have got in contact with me today to say they are going to start replacing parts do people think that's wise just because they can't find the issue?
  2014 Clio 200t edc
Not at all. I wouldn't let them do that. They'll just keep replacing parts until they fix it or you run out of money. Why can't they find the fault? I'd take the car back from them and take it to @MicKPM if he's close to you. It'll be cheaper and a lot better an experience.
  clio 172 cup
Have also notice when I am driving along on cold mornings the temperature goes in the middle then goes down slightly then back up then down would this be coolant temperature sensor?
  clio 172 cup
Reanult said it's not the cts sensor what they think it is is the aftermarket alarm would this cause it to crank over but not starting?
ADS_V6
  172 cup clio v6 st
Andy your gonna end up with a renault big bill,if they just start replacing stuff,for the cost of the fuel take it to someone on here,i had no error codes regarding cts,but replaced it and no problem since with cranking
ADS_V6
  172 cup clio v6 st
i hope u sort it cheaply,cause a stupid bill could pee you off, and think stuff it get shot of the car and you dont want that mate
  clio 172 cup
totally agree mate think I need to take it to a specialist in Surrey just don't know where yet
ADS_V6
  172 cup clio v6 st
how far r u from mickpm ,a tank of fuel or 2 will be cheaper when someone pinpoints the issue straight away
Poopensharten
  Golf R
Have you checked the earth straps? It could be an earthing issue. Try taking them off and cleaning the terminals up, I had similar issues on my old 172 - the temperature guage shot all over the place and it occasionally wouldn't start... The nearside earth strap under the arch liner needed replaced and it sorted it.
It may also be worth checking the electrical relays under the bonnet (three black ones) the terminals could have verdigree or something on them!
  clio 172 cup
Bit of a update have fixed the problem had the key and decoder ring replaced can't wait to drive it been two weeks have a new problem the drivers footwell is soaked if it's not one thing it's another lol
