200,182 Trophy, Cup
I know there are various threads on this but I can't understand why I have the fault
I fitted a retrimmed snappy wheel so all I did was take the old wheel off and put the snappy wheel on.
I can only presume something in the sensor position unit the wheel bolts onto has moved but there seems little to it.
There is a black ring with 2 slots in which the wheel locates into.
Is there something else on this unit which moves separate to the ring.
Is there a way to re set the position or similar or does it require a software plug in
