On a 182. SERV and traction light comes on as soon as I move the wheel away from the centre position. All the lights go off when the car starts up and it works fine but as soon as the steering wheel is moved the lights come on. Any ideas what would be causing this?
When I dropped the subframe to change the clutch a while back, the column came apart on the splined section in the driver footwell, so I assumed the angle sensor wasn't centred. Took the wheel off, put the sensor back to centre (yellow dot in top left corner) but I'm still getting the same problem. The fact it's picking up the movement in the steering wheel and bringing the light on says to me it's still working, but I checked the angle reading on a snap-on diag machine and it's showing 8198 degrees constantly. Unsure if it's just a case of the snap-on machine not reading the data properly though.
