02teasda
Renault Clio 172 Cup
As per title, I have replaced the slip ring on my 172 cup as I had an airbag light on identified as a slip ring fault. Now for my issues.
When I took the steering wheel off it sat dead centre and drove fine. Since putting it back together the wheel is now off to the left with the wheels straight ahead. I have taken the wheel off to check it is on correctly despite the fact it has a master spline and should only go on one way and it is definitely on correctly. I have booked the car in for a full alignment to check but is it possible to force the wheel on in the wrong orientation?
Secondly the steering wheel now seems to be rubbing on something and feels stiffer. It doesn’t seem to return to a neutral position as it should and almost feels like oversteer when I begin to turn.
Has anyone experienced anything similar or got any ideas?
Thanks, Sam
Thanks, Sam
