steering rack part2 pic/vid
  Mini Cooper S JCW
after my post yersterday, got down there again today, n found wot people were talking about...n got a better vid too
on the pic below, with the arrow....... im guessing this is where people have put a bolt thro, or have welded up around?
http://myweb.tiscali.co.uk/tigerseye/m888arc/M888ARC_STEERING3.MPGhttp://myweb.tiscali.co.uk/tigerseye/m888arc/M888ARC_STEERING3.MPG
Above is a vid u can tell pretty easy where the play is n how much!
http://server5.uploadit.org/files/m888arc-Dsc01241Small.jpg
Also, while moving the rubber cover, i noticed a bit of broken off plastic lodged inside it....there woz only 1 half tho?? not sure where the other half is and i dont even know if it was meant to be there anyway?
http://server5.uploadit.org/files/m888arc-Dsc01246Small.jpg
http://server5.uploadit.org/files/m888arc-Dsc01247Small.jpg
http://server5.uploadit.org/files/m888arc-Dsc01248Small.jpg
So what on earth is it!?!
Marc
thats it. the bol goes just behind the red arrow, in the flat part
that plastic part is probably between the rubber hood and the steering column
  20VT Clio & 9-5 HOT
my column is fuked too. but engine may be comin out for new box and clutch so i think ill fit another one then.
bit scared about taking the lump out myself though. bit of an amateur! lol
Just weld it up. Thats exactly as mine was. It can be welded in situ. I know of a good welder in norfolk who can do it for about 30 notes, but any decent welder could do it. Dont have to take tghe column out either.
  20VT Clio & 9-5 HOT
my mechanic refused to do it, said he didnt recommend it. i reckon it would be fine though.
  Mini Cooper S JCW
Quote: Originally posted by moggs on 11 March 2004
I screwed some self tappers down there, one either side. sorted the problem till i can get it welded.
do u think u can get me some pics of it matey? its getting pretty bad n i havent had a change to look for a welder etc?? need a quick fix
much appriated mate
Marc
