Steering Wheel - Changing from an expression to a dynamique.
  Shed.
Very likely im guna buy a dynamique steering wheel because im sick of my poverty plastic one.
Are they easy to fit, are there any guides about to doing it. also, the one im after doesnt have an airbag, can i use the one from my expression steering wheel ????
ta.
-KarL-
yeah airbag should fit,
pretty easy to do unhook battery for about 30mins
look behind the steering wheel and you will see 2 clips holding the airbag in get these off ( i used my pocket knife and used the tin opener bit :eek: )
then the airbag should pull off and should be 2 clips going to the airbag, just un plug them that it should come off.
then use a torx 50 bit to get the wheel off
  Shed.
dont mean to be a retart but whats a torx 50 lol.........]
will give it a try then. sounds easy enough. lol.
ta v much.
-KarL-
lol its a star shaped thing that you will need to get the wheel off,
i got mine from halfrauds only about £2 or so
