Steering wheel not straight?
  Nothing at the mo :(
I dunno if this is normal, Or is just the camber of the road
But sometimes when the road is straight my steering wheel is turned to the left slightly. I have had it tracked and its all fine. Is there something else i should look at?
yeah i thought it might be road camber, im popping out in a minute so il try it then
What if it still does it?
get the tracking done again free - should include steering wheel alignment in the service so they may have not done it properly.
You don't adjust the steering wheel - the adjustment at the wheels can lead the steering wheel to be out of position when driving, they clamp the steering wheel and then adjust the wheels to suit.
^^^ The above happened when I took mine to Tweaks, got a refund and took it somewhere else. Now straight with no problems.
road camber most likely, or a bit of tramline torq steer init:rasp:
I just can't get over your username fella lol!
riz
  Jaguar XFR
MY 182 never had a straight steering wheel ever. 2 tracking places coudlnt get it done
as said, it'll just be the camber of the road pulling the n/s wheel, unless it's also noticeable on level ground
tracking's adjusted by releasing and then adjusting the track rods on the rack - it's obv. all connected so, unless they're very careful, it'll pull the steering wheel about as well. it's difficult to keep the steering wheel dead straight tbh - just take it back and ask them to have another go if it's annoying. some are more careful than others
