i have just fitted a performance clutch to my valver thay are very heavy on the pedal you should ask the person you bought it from if they fitted a clutch if i remember both the 16v and rsi have heavy clutches anyway. some one say something if i am wrong
yeah the mk1 clios all have farely heavy clutches especially the valvers. something you get used to, but if you feel it is extremely heavy then at a guess could be clutch cable frayed?
If clutch is standard it shouldnt be that heavy.Check how the cable is routed as it comes through the bulkhead.If its fully clipped to the subframe,undo the first to give a more gradual curve around back of engine.If no improvement,replace cable £15ish.Should solve problem?
