Straight through on standard backbox?
My standard centre section has loose rattly baffles. Buying an aftermarket system is currently not an option.. so whilst im saving up/decided what to do... :
Thinking of just taking it to the local exhaust place and getting a straight-through pipe fitted with no silencer, instead of a new center section.
What are the implications of this? Will it sound different? Will it pass m.o.t / emissions etc?
fil_b
  172 FF and Fabia VRS
its the cat that sorts the emissions
maybe louder as ur taking a sliencer out but what it will sound like i dont know
Paddy_g46
that is what im currently running on my car. Sports cat, straight through centre, and standard back box, Nice and raspy but not boomy! :)
E11OOT
  182/V6/R27/R26R
it will fail on emissions if you remove the cat, it's illegal without a silencer IIRC. you will here you car from about 10 miles away as well.
  Ph1
A silencer dosent mean your restricting the exhaust in anyway you know. Only the cat does that.
Take the cat away for example and all exhausts are ''straight through'' as in you put a golf ball at one end, it will roll out the other.
Removing silencers just means you make noise. No performance gains or loss
Not sure about noise limits at MOT time. I know on a track theres restrictions
  S4 Avant
There's some misinformed people in this thread.
Adding to the reply I've just sent you, shouldn't be a problem just finding somewhere to cut out the broken scilencer and replace with a straight through pipe.
Will be slightly louder, as you're removing a scilencer, however the standard back box should do a pretty good job of keeping the noise levels down.
Not a problem with emissions as the cat will still be in place.
  alien green rs133
not all standard silencers are "straight through"
or at least the standard renault ones i have seen.
centre section on a megane 1.6 for example similar design exhaust so just guessing
(your golf ball would get stuck :rasp:)
Thanks dave, btw in reply to your pm took it to an exhaust center who did say it was the center section, think i already checked heatshield etc. IF not, im sure they did but i will double check it before getting any work done :)
