M2,XJS,S1000RR
Right then, need some help/answers if possible.
Fit girl at work has a 10 plate TT petrol Turbo on 44k and we think it's fooked. Wednesday morning she pulled up at work and it was running fine, just like normal, she comes to leave and the car won't start at all. It turns over and the starter motor spins but nothing at all. Checked some of the usual simple suspects and nothing changed at all.
Local garage we know had it in today for a quick look and initially thought it was the timing chain snapped, which I know wouldn't be the case! Long story short they have done a compression test on it and all 4 cylinders have 0 pressure, so all of the air is getting out somewhere. I'm thinking that it could be the tensioner failed, bent the valves slightly and they now aren't sitting right?
I can't see it being cracked pistons, rings gone, or a hole in the block covering 4 cylinders.
So we're a bit stumped until the rocker cover comes off, and I'm ridiculously interested since it's a bit of a weird one!
Anyone help?!
No pictures I'm afraid, would be weird.
@Chip-mk1
@Gray - meant to ask you earlier but forgot!!
Anyone help?!
@Chip-mk1
