strange noises yet again
Car  Ph 1 172
hey people this is my sometimes when i break my front right tire area makes a strange noise sounds like a bit of grit in the disc brake. i have checked both brakes on front (passenger and drivers side) and nothing in the break then i noticed the bar that comes from the middle of the car and goes to each wheel that it is covered in oil on one side and not on the other. im worried this is another driveshaft gone??? anyone got any ideas how to fix it or if it is something else other than drive shaft??
o right how can i check to see if it has and how much does it cost to get it fixed just worried coz of strange grinding noise when i slow down, although no noise when i accelerate hard or go round corners
There will be a thick like oil on drive shaft and when you squeeze it grease will come out if it is that and you don't sore it soon it might damage your bearings
right so is the gator the thing in middle of car were to drive shafts meet last question i promise lol cheers mate
Its ok ask as much as you want there is one by your wheel and 1 by your gearbox
