strange noises
  172 sport
im after some advice if possible i have a 172sport ph2 51 plate everything was working fine yesterday apart from the hazards coming on now and again whilst driving middle of night i get knock at door hazard lights switching on go to knock them off and holy hell breaks loose the alarm keeps going off wont shut up unless i leave doors unlocked (not good where i live) then put key in ignition this morning get some weird noise and speed- ometer is kinda going crzy it looked like it was being held by something any advice on potential problems or work i can do to fix it up cheers and thanks for reading the long message guys.
kris
  172 sport
Well had a mechanic to look at it said its one of 2 things uch whatever that is and said all the relays are buggered all corroded and the board where the relays go has water in it oh and the battery is very low but I can charge that up anyone know what I should do next any advice please thanks all
  E46 320D Tourer!
Yep, sounds like uch matey. Loads of threads on it on here. Have a search about. There's a place that can repair uch's and is far cheaper than getting a new one.
Only other option is to buy a second hand uch/ecu/key(s) off eBay or someone on here and fit them instead. Don't try and jut replace the uch as its paired with the ecu.
  172 sport
I have no idea what a uch is mate the guy wants to replace all the relays as Said that could be it what u think and how much u reckon these things cost cheers for the reply.
  E46 320D Tourer!
Dude, where abouts are you in the uk? I'd be inclined to go to a Renault specialist and get a proper job done. Please don't let some random garage mess around with it, they'll just get you spends more money than you need too. A Renault specialist will diagnose the problem straight away and fix that rather than fixing everything but the main problem.
If you let me know roughly where you are I'll have a look and see where your nearest specialist is. Or join as a full member and you'll have full access to the information!
The cost of the membership will be saved in the specialist doing the work for you!
  172 sport
Cheers mate so you think hold fire for a moment on getting te relays changed (even though they are corroded to hell and back) j live in a Wales near aberdare mate thanks for the advice
  E46 320D Tourer!
Had a quick look on here and your nearest specialist would appear to be these guys. Worth a punt even for a second opinion.
A P Developments, based in swansea. Call:01639 845 009 | Mail:
info@ap-developments.com
APD, Unit 5 Gurnos Industrial Estate,
Ystalyfera, Swansea, SA9 2HW
  172 sport
Yea will drop them. Line now mate I spoke to mick on here do hoping he has done good advice jus gutted I cannot drive it but there u go thanks for the advice mate much appreciated
  E46 320D Tourer!
There are mixed reviews of his work on here, but considering your car isn't drivable and the nearest after him is north Wales........
  172 sport
Well it's now drivable mate got the relays cleaned up and board cleaned then had bat checked ur showing 8.1v shocking so changed bat at started first time just get the alarm going off when I open the door any idea.
